Enables you to forward packets for the UPnP protocol to the VLAN for learning.
| flood | Specifies to forward UPnP to VLAN. (Default). |
| learn | Specifies to send UPnP to the CPU for learning. |
flood
Use this command to enable UPnP for flood or learn state.
When flood to VLAN is enabled, an actual ACL filter is installed, and one ACL entry is consumed.
When in learn mode, no ACL filters are installed, and no ACL resources are consumed.
The following command enables UPnP to flood to VLAN:
configure forwarding ipmc upnp flood
This command was first available in ExtremeXOS 32.2.
